tranny issue at WOT
turbocody
GOT BOOST!
hello guys, i took the car out last nite and did some testing and i noticed the car would rev higher before it shifted into 2nd, and some times it would hit the rev limiter for about 2 seconds and then shift. it shifts fine 2-3. the tranny is a stock 53k with a extra cooler and a shift kit. i just replaced the TCC solenoid and fluid and filter. right now the fluid level is between the add & full mark.now i have heard some people say that if you do not fill the tranny to the max or overfull a little bit then the filter cannot pick up the fluid it needs. is this true?? is that my problem?? i have not touched the T.V cable, do i need to adjust that as it may have got out of adjustment? ANY input is better than none :)
Thanks,
