Transmission Shifting Too High
nascar
It seems that my transmission, (87) GN, is shifting into OD about 10-15 MPH too early causing the car to bog. Any solutions?
if all the shifts are early adjust the tv cable tighter .if its only overdrive you may have to replace the 3/4 shift valve spring w/a stiffer one or one out of another transmission .i have seen this with overheated transmissions that were rebuilt.the overheating baked the tension out of the spring making them softer.
