Just installed LC-1 and PL. I performed all the necessary calibrations for the LC-1. The sensor is reading correctly and the led indicates it is functioning properly.
I am using the LM programmer to try to program the data to represent AFR instead of Lamda. When I select this option (for analog 2) the "program" button does not activate, thus not allowing me to program. Also, when I connect the LC-1 to my laptop the led flashes, but stays on steady otherwise.
Any help getting this thing programmed would be much appreciated!
