Last week end I started to tune I have 42lbs injectors and a TT 93 oct street chip running 17lbs of boost and fuel pressure is set at 43lbs line off, I made 3 passes 1)777-0.0 degrees 2)750-0.9 degrees 3)753-2.1 degrees I see that I am a little lean and going to add fuel in the chip,how much fuel should I add?Also this week I added a stock intercooler with Dutt neck how much will this change my boost? My #'s at idle are as follows:
AF 5
L8 34
bat 13.8
Int 128
BL 125
Clt 168
Ats 85
r 750-850
Tps .44
Iac 34
cc at idle stay's steady/at cruise goes up by 10-20 counts
*at idle has a little stumble it smooths out at 1,850-2,000 rpms
*fuel goes up 1:1 with boost/WOT 60lbs fuel press
Any help would be greatly appreciated.Thanks,ikle.
AF 5
L8 34
bat 13.8
Int 128
BL 125
Clt 168
Ats 85
r 750-850
Tps .44
Iac 34
