I personally do NOT agree with the 360* oiling groove bearing theory. The main bearing acts as an oil pump to pump HIGH pressure oil to the rods by way of the cresent shaped clearance between the crank and the main bearing. By cutting a groove in the bearing to supply oil, you reduce the load carrying capability of the bearing, AND reduce the pumping action by giving a secondary path for the high pressure oil. There is also controversy surrounding the cross drilled crank theory, too. Oil passage "timing" is critical to supplying the high pressure oil to the rod journal. There is ALOT of engineering that goes into a crank oil holes, they're not just hap-hazardly drilled. Think about having the oil hole timed so high pressure oil transits when the rod is at bottom dead center. Then the high pressure oil is not there when it is needed the most. By cross drilling the crank you risk having a second opening at the wrong time for the high pressure oil to back up through. Food for thought.
Now I DO agree with the cranks all being the same, though.
