I concur.
T63 big shaft, means it has a 63mm compressor wheel, big shaft is the actual diameter of the turbine wheel's shaft. Garrett makes both a big shaft and a small shaft P-trim turbine wheel. The P-trim turbine wheel has a trim of 76.
Here is a picture that describes what A/R is.
And here is a picture that shows you how to properly measure a compressor wheel and a turbine wheel's inducer and exducers.
And again, here is the page that tells you alot more information about trim, A/R and more.
TurboByGarrett.com - Turbo Tech102
Garrett made both the big shaft and small shaft P-trim turbine wheel, so that it could be used in both T3 and T4 style bearing housings. The small shaft P-trim turbine wheel has been used in the PT67 turbos since their inception.
So if you have a LT70 P-trim turbo, Royal is correct. It is a 70mm compressor wheel, with a large shaft P-trim turbine wheel.
The .63 is the A/R of the turbine housing and depending on whether it's a Precision housing or a Garrett housing, can alter your torque converter's stall requirements. Sounds like your T63 was upgraded to a LT70 which is a very good upgrade. Should be around 50-60 flywheel hp difference between the 63 and the 70 P-trim turbos. If the label says LT70 P-trim, and it came from Limit that way, you can bank on it.
HTH
Patrick
