Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
Racetronix double pumper with an8-AN6 lines with a fat tune. Alkycontrol with dual feed.make sure it has lots of fuel
SignUp Now!Racetronix double pumper with an8-AN6 lines with a fat tune. Alkycontrol with dual feed.make sure it has lots of fuel
ive run the pte.85,pte.63,and the turboneticcs,82 and .63 and they all have been in the 9's.its all in the comboHi guys, are you guys running the big hpc 64mm with the stock .63 Tnetics a/r housing? There should be some sort of match between the comp wheel and a/r housing.
.63 Tnetics is similar to the Garrett .63...Its a 500-515hp a/r.
I agreeThere should be some sort of match between the comp wheel and a/r housing.
very good,sent you a pmRacetronix double pumper with an8-AN6 lines with a fat tune. Alkycontrol with dual feed.
what makes you think im limited on a 3 bolt Ive seen over 800 with oneTo bad you guys are limited to 3 bolt housing
the ex housing is not a restriction on an iron head at 21 psi.must have been something else if that's what you have truly seenWe have the .82 turbonetic give us 4 moré miles in the 1/8 on the same bust 21
I was talking about a $550 turbo that will make the same power as a $1000-$2000 turbo. You don't have to convince me, I know the 3 bolt configuration works.what makes you think im limited on a 3 bolt Ive seen over 800 with one![]()
I don't know what limit of a 3bolt but I do know it supports more than 95% of the guys on here will run.. I know its been deep 8s.. Does anybody know what the limit/fastest a turbo Buick has gone in a 3bolt?I was talking about a $550 turbo that will make the same power as a $1000-$2000 turbo. You don't have to convince me, I know the 3 bolt configuration works.
now I understandI was talking about a $550 turbo that will make the same power as a $1000-$2000 turbo. You don't have to convince me, I know the 3 bolt configuration works.
Its not really a $550 turbo since a supercore does not have an exhaust housing. I have a 366 that was machined to go in a Precision .82 3 bolt housing that works really well. We just put the new 369 4 bolt on a 109 motor with TA heads should be running any day. I think it will be very fastI was talking about a $550 turbo that will make the same power as a $1000-$2000 turbo. You don't have to convince me, I know the 3 bolt configuration works.
Bayahahahhaha!!!!Atr doble pump have so upgrade de lines is next ...well alki too. Thanks gays For the advice
