Turbo for sell
GN GURU
Don't worry honey this one is the last one
Hey guys up for sell is a turbo no play up & dn or side by side throwing in boost controller & adjustable wastegate box ready to ship!!!
I don't remember what size it is I think 60 or 61 any help checking what size it is would be appreciate thanks again asking price is $500 lmk
Pics any more pics or info upon request
Hot side pic
with 7 blades i think it is in the 60s range, i think to get a true size you have to take the comp housing off and measure the wheel. What brand and size of the exh housing. I am not interested but these are ?s people will need to know so i am just getting you to answer them before they ask.
That is a precision housing, looks like a .83 size, does it have a size on it .83 or .63. That is a lot smaller hole for the downpipe compared to my te62 mine had like 1/8 inch or less of meat for the dp to seal, puck hole is pretty small too.
Hot side is 63 it says it on it
if it is a 63 that is good as that is what most people want, i would say it is a te60 as the 61 and 62 have alot bigger exh wheels, and it is not a te44 as yours has 7 blades and a 44 has 6, so unless there is something between a 44 and 60 i would say it is a so series. Good luck with sale.
forcefed3.8's said:
It has a 10 blade turbine wheel and a 60-1 compressor. I am guessing a PT52.
. E cover 60-1 small shaft comp wheel and t350 (aka stage 5)turbine
Bison,I have a turbo identical to this one other than mine has 11 fins on the hotside.any idea of what I'm working with?thanks
You would need to measure the inducer/exducer of the turbine. The 10 blade one is easy to i.d. because it was the only one used in the t04e turbos back in the day other than the huge GTQ turbine.
