Put grease on the puck surface, install elbow, close puck, remove elbow, look at grease pattern. if it covers the hole completely, you will be fine.
For the stock actuator, it will have to be modified to work on a TE44. I only run stock appearing stuff, so i can't help. Steve Wood has explained the mods necessary. He is your best bet.
