t-typinator
- Oct 8, 2010
My car has a goodly amount of turbo lag,it makes great power once the boost hits,but seems to take for ever to get into boost,(Seems to run fine other then some knock well into the boost)It does have a big turbo,I believe it's a te52, but stock heads,cam,It does have the orange stripe converter which should help some of the lag,also has the 3" downpipe + 2.5 exhaust.
A local buick turbo guy says, get rid of the headers,+ it will make WAY more low + midrange power,because it will spool that turbine up much quicker,+ not hurt the top end power any.(Because the stock heads really can't utilize the big volume of the headers)
His suggestion is that with the big after market headers,their is no exhaust "Velocity" to spin up the oversized turbine,(especially with the stock head,cam,intake setup.so it causes alot of lag especially with the big turbo,he actually put headers on his wifes mostly stock car + ended up taking them off, because he lost so much usable low/mid range on the street,said it was a dog,+ tells me to go back to the stock manifolds + it will be like night + day. unless i'm going to really build the motor ,+ go with a high stall converter also.
I'm selling the car so this is more to help the new owner dial it in,but i'm also curious too.Anybody else have the same experience or share the same view. Thanks in advance.
