TURBO MOTOR / STROKER MOTOR
GNXJohn
109 Block 030 over forged pistons, billet center caps, ported champion aluminum heads, roller rockets 206/206 hyd roller cam, stock intake, 50 injectors, flexplate, 2K miles on motor Built by Huntsville Engine Performance $4900. 4 pics.
Stroker motor Weber stroker kit Girdle, 85 block #239, Champion Aluminum ported heads T/D 1.6 roller rockets Comp hyd roller cam 218/218 deep oil pan. about 3k miles on motor. $5900. 4 pics.
Stock turbo motor and trans. out of 87 GN 66k miles Ran good Not a turbo trans $2200. 2 pics.
If someone just wants the short block on the stroker motor I am interested in the top end and valvetrain if the seller will seperate.
How much for the short block?
any oil leaks from the girdle?
and i forget the 85 Block is 14 bolt pan... right? But everything else bolts on the same as 109 correct?
-aaron
