I have a small "weeping" leak where the turbo oil drain tube (87GN) attaches to the fitting in the engine block (*not* where the fitting screws into the block).
Before I take it apart or tighten it, had a question -
Is this a metal-to-metal compression fitting? Or is some kind of seal or gasket used?
If it's the first, I'll probably just tighten it slightly. If it's the second, I'd want to have a new gasket/oring on-hand, before I attempt taking it apart.
TIA.
TIA.
