Turbo Oil Return Line in 4.1 L
GN2
Will it be alright to run turbo oil return line into blocked off mechanical fuel pump plate in a 4.1 L?
I put mine in the same place in the block just like my 3.8 .. looks factory that way too.
Got mine in the ing mine fuel pump spot, if you drill a hole in the 4.1, there's a chance you weaken the block! Thats where they crack when drilled. Been running mine for 3 years, and I just freshened it up, all looked good when I pulled it down. I have ran 25lbs boost, and more stll rolling, no girddle, just stud, and stock main caps!
did it on my 82 block and worked fine also. There are a lot of people that have done it this way.
I have had two blocks with the return in the stock 3.8 location. I now have it in the oil pan due to new turbo location. This was never an issue with it in the stock location.
