LOL, I know Im slow! I ride the short yellow bus.
So to pre turbo misting.
I thought about that, but decided that it wasnt a good idea, I will be injecting AFTER turbo though. My thoughts were as follows...
Since we are dealing with drawthru... the air/fuel mixture is taken in by the turbo, air/fuel as we know has mass, even if it is so light we can barely measure it.. but it does! the more mass we load the turbo with the slower it is going to spool - a problem only encountered by us typicaly.... So if we add more to the mix with alcohol/water were only slowing down the turbo by forcing it to move more mass. This sounds crazy, and hard to understand... but think of your car moving through the air... the thicker it is the harder it will be for your car to go the same speed for the same amount of power! and the faster you move through something thick - the harder it becomes........ now imagine a turbo spinning at 100K rpm.... how much resistance do you think it is encountering?............Hmm..... some food for thought.
Not to mention, it just seemed like logic to me that - if you inject pre turbo where the air/fuel mixture is.... the alcohol/water mix is only going to displace the room that could be used for more fuel/air. the more **** the air is already carrying the less fuel it is going to pick up and atomize correctly. In my opinion, if i could just use the carb more as a throttle body to control idling, low/midrange fuel delivery and use a mechanical port injection as the main source of fuel under power. This should increase volume and reduce the heating during the compressing of the mixture....
Theoretically that is!
alot of this information I pulled from a Studebaker Avanti power manual.... that runs a Paxton drawthru centrifigal supercharger, Bob Sazabos guide to mechanical fuel Injection and the linear flow of air, Gene Mooneyham's Guide to highpower Roots blower systems, and the Hand Book of Hydraulics (forth edition).
:biggrin: A.j.
