Turbo replacement
wbzautocustomiz
Want my GN to go 11's one day
Stock 87 TR mild mods boost gauge is only showing about 5-7 lbs boost WOT and blowing a little white smoke after driving coming to stop then restart smokes little, could turbo be bad? if yes whats best way to go about it rebuild what I have or go with a upgrade? Thanks
Mods are only no cat, 2 1/2" S.S. exhuast, tt chip. i had cracked manifolds when i had turbo off car welding cracks noticed the turbine looked to be chewed up and since I put back on I have this smoke thing going on and plugs are good even put new opnes in when I pulled to check, intercooler hoses ok, nothing in oil so far. I thought maybe if play in turbine can cause smoke.
turbo could cause smoke. if the blades are chewed up send it in or get a new turbo.
Can anyone help me? If i need to replace stock 87 turbocharger whats a good match, size, style,. brand, wastegate, boost controller? Car is stock just chip and exhaust
te44/ta49 are proven turbos for a stock ride. you can also go with a gt 6131E which should still work ok with the stock d5. i would call precisionturbo.net and talk to them. they will set you up for what you need.
