- Aug 11, 2001
Slight Change to my setup requires me to part with some real top of the line quality parts.
PLEASE do NOT waste MY time, serious buyers only, PLEASE!!! Don’t hesitate to ask any questions you might have. Preferred Cash local pickup, especially for the bigger items. Local pickup is Oceanside (Long Island), NY 11572
(Like New)= Slightly Used with approximately 1,500 miles (unless otherwise noted)
1) Siemens Deka SD 225 lbs Injectors Low Z pfu041-2250 (set of 8)_$1,750 or $250 each (stipulations, ask)
(Like New with less than 500 miles) Very hard to find, the best Injectors in the business
2) Caspers Holley Engine Harness with Holley Smart Coil Harness/stock location_$1250 shipped
Brand New with EV1 Injector Harness, Holley Smart Coil, Grounds, Distribution Block. Everything you need for a direct hook up for your Holley EFI
3) Stage 2 On Center 153 Virgin block with New Arp Main Cap stud kit (NEW)_$5,900
4) SOLD-Comp Cams XR3 216/220 Hyd Roller Cam with Morel Lifters (Like New)- SOLD
5) SOLD- TurboTweak ecu-GN (Blue Box- needs Tuner Studio) (Like New in box)- SOLD
6) DeatschWerks DW 88 lbs High Impedance Injectors- E85 Compatible (Like New in box)_$315 shipped
7) SOLD- PTC 2004R 9.5 N/L Converter 17 Blade (NEW)- SOLD
8) Racetronixs Catch Can complete setup with one-way check valve, An fittings/hoses and PCV_$200 shipped
Real nice and functional setup (Like New)
