forcefed3.8's
Buckeye Bullet
- May 26, 2002
New Precision 6665 cast wheel turbo. E cover, .63 turbine housing, never used. I painted the centersection so it won't rust, POR15 manifold paint on the turbine, and cast aluminum paint on the compressor so it cleans easily. This turbo is the same a TE45a, but with the newer high flowing F1 10 blade turbine. High 9 sec potential, easy low 10's with supporting mods. $700
76GTQ with .85 turbine, S cover. Was just rebuilt by Precision less than 500 miles ago. I went high 8's with this same turbo. $500 SOLD
PT54, .63 turbine, e cover, with actuator, low miles. A very good high 10 sec turbo, good for a stock long block engine $425
(2) .63 Garrett exhaust housings for T31 wheel, TE44, TA49, TE/TA60, 6131, etc $125 each
95lbs injectors, little usage, used with C16 $225 SOLD
MSD 50lbs injectors, $125
Stock ECM modded for low impedance injectors $150 SOLD
Scanmaster 2.2 and Powerlogger board. This is just the board that goes into the ECM, the cables and interface can be bought easily from Bob Bailey. $275 SOLD
Aerospace Components front drag brakes, used a 1/4 mile at a time, at Bowling Green and Norwalk for a handful of years (5 maybe). They are brakes, they get dust on them, but work as should. Come mounted to modified stock spindles and braided hoses. $500
I have a rebuilt short block with .030 over TRW pistons, ARP main studs and rod bolts, crank turned .020, 212/212 roller cam, Comp roller lifters, double roller timing chain, front cover. The engine has been run since rebuild. It came in a car I bought. $1500, local pick up in 44039
All parts are plus shipping.
