TurboTweak 6.0 chips for sale
turbov6joe
Signal 1 J-12
I have 4 Turbo Tweak 50# alcohol chips for sale. These are the 6.0 (revision 1955) wide band adjustment chips that have the following options.
1. WOT a/f ratio 1st and 2nd gears (9.7 to 12.5)
2. WOT a/f ratio 3rd and 4th gears (9.7 to 12.5)
3. Part Throttle PE a/f ratio adjustment (9.7 to 12.5)
4. Base WOT fuel adjustment (-23% to +23%)
5. Spark Offset 1st and 2nd gears (-10* to +10*)
6. Spark Offset 3rd and 4th gears (-10* to +10*)
7. WOT TCC lock MPH (30-105 mph, 128 off)
8. Wideband O2 offset (1-20)
Chip #1 has a base timing setting of 26*/21* for 23-25 psi
Chips #2,3,& 4 have base timing setting of 23*/21* for 23-25 psi
These chips are adjusted through either Direct Scan or Scanmaster by using the gas pedal. They come with full user/programming instructions. Wideband O2 required with a 0-5 volt input/output....Example PLX300 type system. If using Direct Scan you can log the wideband O2 a/f ratio throughout the pass.
$85/chip shipped. Paypal accepted with addition of 4% fees. Please don't PM me, I cannot read them for whatever reason.
Chip 2,3,or 4 with 23/21 timing, it says they are the same correct?
ill pay ya via paypal, just let me know which email to use and ill tack on the 4%
I have 3 Turbo Tweak 50# alcohol chips for sale. These are the 6.0 (revision 1955) wide band adjustment chips that have the following options.
Chips #2,3 have base timing setting of 23*/21* for 23-25 psi
$85/chip shipped. Paypal accepted with addition of 4% fees. Now able to read PM if you wish to contact me there.
Price reduced
$73/chip shipped.
Prices reduced
$65/chip shipped.
Prices reducecd for quick sale!
Price reduced again.
Chips #2, & 3 have base timing setting of 23*/21* for 23-25 psi
$55/chip shipped. Paypal accepted with addition of 4% fees. Please don't PM me, I cannot read them for whatever reason.
Prices reduced again.
Sup BW, it's going pretty good...can't complain. Yup, this weather pretty much blows...I'm ready fo spring already! What's new with you? Get moved into the new casa yet?
I hear you! spring is only 3 or so months away for us...., moved alot of snow at work and thats about it...
They are staying in the house probably thru feb, so this march i guess...
Moving will be quite the task.
Heard from Neil you bought a ford product :) Thats awesome, no wait,... better than awesome :biggrin:
BW
$45/chip shipped.
Prices dropped
Joe,
I'll take one of the 23/21 timing chips. Will send the Paypal today.
Thanks,
Mike
Joe,
Thanks,
Mike
Ok, thanks. I'll try to get to the PO today before they close at noon...if not it will be Tuesday for sure.
