TURBOLICKER
- Nov 9, 2005
Does anyone have a definitive list of part numbers for the UB machine uppers? What is the stock replacement number? What is the number for use with B-Body spindles and what is the nuber with bump stops and anti dive plate? I've called them and can't seem to get exact info!!!What is the stock length on our arms? I remember that using stock arms required 1/2 inch spacers or offset upper shafts so I assume a B-Body brake set up would use an arm 1/2" shorter.
Thanks!
Thanks!
