- Jan 19, 2005
i dont have scanmaster, and i dont know how to open that file
SignUp Now!So, rather than increase boost to offset the rich condition, they turned down the alky?
Were they locking the converter up? How does the car run & feel? Dyno numbers don't always tell the whole story.
I don't see a pull over about 4500rpm.. What's with that?
same question
Why don't you ask Kevin King why the car dynoed low numbers? Everyone has a different opinion, I don't think that 11.3 is that lean considering the timing. My suggestion would be to talk to Mr. King and possible have a chip burned for alcohol injection.
A 98 octane chip is not the same as an Alky / Meth chip. More timing is available on an Alky chip & fuel is scalled back to compensate for the Alky. A new Turbo Tweak chip burned for your exact combination of parts would be my first step & retune from there. Was this a KDK combination that fell short of your goals or your creation that you had them try to tune?
That i did not know.
it was more or less a creation they tried to tune. The car was bought from a family member who didn't have time to finish it.. unfortunately i ran into this same problem so i thought the last piece was to tune it.. so i dropped it off at KDK.. I'm not upset at them by any means, but i think they could have gave me a couple of different options or tried to troubleshoot why it wasn't making good numbers more then they did. I know they are very busy and have tons of cars waiting.
He didn't know about the numbers.. I think they were somewhat anxious to get me out because I kept harassing them every week.
the chip is burned to use 98 octane all the time, ie; meth.
Get you out of where? You paid them money to tune the car, right? Kevin seems to be a reasonable guy and if he is not willing to answer some simple questions about the tune, I would take my car elsewhere. Personally, I think your dyno numbers are OK for a hot-air at that level of boost. Considering the modifications that have been done to the car, I think you might have somewhere in the area of 300 hp. A chip made for alcohol will make a difference. I would take up the Under-Pressure's offer to give you a hand with you car. Always nice to have a helping hand..
At your curreny level of boost, than Yes..If your goals are mid to high 300s than you goal can be achieved through more boost and timing. Boost will get you to your goal..
21 lbs?? i figured the turbo was much better then that considering its good for mid 500s at the crank.. then again there are alot more variables.
Hello all,
I'm a new member here and just got my car tuned by KDK in Orlando FL.
I am pretty unimpressed with the results, they are closed now but I was told it was putting out 270hp to the wheels at 21 lbs with a almost perfect a/f ratio.
Mods are as follows;
1985 Buick T-Type
1987 ECU
Spearco Intercooler Part # 2-135
Turbo Turbonetics, Cheetah .63
Razor Alkyl meth kit
GReddy Profec B2 Boost Controller
Kenny Bell Headers
Kenny Bell Air and breather filters
Walboro 340 Fuel pump
Hot wire kit
Extender Chip
2 ½ straight dump downpipe
MSD 50 Lb injectors
Lt-1 Maf
Translator
Bosch Adj fuel pressure regulator
2004R Shift kit rebuilt with all new performance parts
2800 Torque Converter
Camshaft 231t 0.519”
V-8 Radiator
The motor has been rebuilt from top bottom, i was hoping for mid 300's or close to 400 to the wheels.. is this an unreasonable expectation?
please provide some input.![]()
I'll bet that if you run a bit fatter in the A/F (about 10.5), lower the timing, more alky, and add boost, you'll hit your goal.
11.3 seems a bit lean....although it varies from car to car.
