750H.P.V6
Brutal 6 Racing
- Sep 4, 2001
Veljo,
I don't want you to take this the wrong way as I know you weren't soliciting opinions about your combo but I suggest you get some different connecting rods. A Carillo rod isn't really up the task at the H.P. level your at and the ones you have pictured are the light weight versions. What typically happens is that they will bend under heavy compression loads then break. An " I " beam rod is much stronger.
Neal
Neal
