Using power logger with alky kit
jmidolo
Sexy MF Joe
Just installed my PL last night. There is an option to cut the green wire and use it for boost sense in the PL. I remember doing something with the green wire when I installed my alky kit.
Does this interfere with the operation of the Razor kit or not an issue?
no problem at all, works well.
run a wire from the green MAP sensor wire (under hood or under dash) to input 2 of the Powerlogger analog input unit.
Bob
Bob
If I remember correctly, I have already run that green wire into the car for the alky control right? Probably easiest to pick it up there if you can point me right.
Input 2 of the PL...is that the connector I don't have hooked up right now that uses a ps2 connection?
Yup. I usually go under the dash and tie into the green wire there and run it behind the stereo.. Or you can go to the multi-pin clear/black connector and pickup the green wire there.
No problem.. :D
