vacuum block gasket and oil drain back gasket
t3intercooled
I was wondering if anyone knows if napa or oreillys carries those gaskets and if so the parts number. they dont have any idea what im talking about...I know I could make the drainback but the vacuum block is a bit tougher. and I know oyr wonderful online retailers cover them but I am in abind for a running vehicle which is why im trying locally
Hey..... I have a few of those gaskets. When I get home from work, I will try yo remember the look at the packaging for the part numbers... I will send you a PM with my number for you to call this evening. I am in Az, so your aware of the time diff!!
Sent from my iPhone using Forum Runner
Vacuum block is GM# 25536028
I cant find the oil return one at the moment. I will continue to look
I made my own oil return line gasket out of material I bought at AZ. Has yet to leak.. Fingers crossed.
I have a set of punches and a sheet of gasket material. I have been making my own gaskets for years.
Standard also makes an Throttle body gasket set and its a couple of bucks. Part# 2004.
the oil drain back gasket is the same as an egr gasket for something or other- bring the drain tube in to the store and match it up against the gaskets hanging on the pegs on the wall..
