shumpertdavid
- May 13, 2004
I've got an 82 regal with a Carb'd 3.8. Currently it has a basically stock long block with a comp cam on a 110 lobe serperation, intake, carb, headers, 125 hp nitrous. I only make about 7" vacuum idling in gear if memory serves correct. My problem is that when making multiple low speed stops or like moving through the staging lanes up to the line, I run out of braking assist as there is no vacuum. My new engine combo will be 10:1, more cam than current(lift & dur) with a 112 lobe seperation, ported heads, and more nitrous.
My Question is; is there anything I can do to get better vacuum assist(different year\style booster, things like that), or would a conversion to hydroboost work better for me? I saw several posts where Turbo owners were converting to vacuum so wasn't sure.
Any advice\help would be greatly appreciated.
