I like the look of the stock valve covers - and consequently retained them when I installed T&D Roller Rockers.
I bought a set of VC spacers from Jason and would like to hear the consensus on the "best, most effective" way to install them.
Last time, I used that Permatex stuff in the "Cheeze-Wiz" Bottle (Right Stuff) and glued them directly to each cylinder head, installed the aluminum spacer, and then the VC Gasket - which seemed to work fairly well (leak free & easy removal of VC should I need to).
Also, the VC Gaskets I have now seem very nice. I know I purchased them locally - and am curious if they are re-usable. I am pretty certain they are Fel-Pro. They are rigid with metal re-inforcement in them, along with some "blue" colored material around the perimiter. Is it ok to re-use these gaskets? They do not appear to be visibly torn or distorted in any way.
Many Thanks !!!
Many Thanks !!!
