Edit: title should say CHAMBER not cyl inspection..
Have my heads apart and want to see how good the valve job has held up (or was to begin with) so I marked up the seats with black magic marker and turned the valves some to look at where the contact is.
What is the preferred method? Spinning them all the way around or just 1/8th turn? I read somewhere to only turn it 1/8th.
What am I looking for exactly? It seems like a lot of the intake valves have a very narrow contact area.
The other thing I noticed is that it seems like my passenger side head ran hotter than my drivers side head. Especially the #6 cylinder. I have polished chambers and you can see significant discoloration from the heat on that cylinder. The exhaust valve also seems to have a baked on layer of deposits on it (the other valves are clean)
Is this a common air distribution issue? Or is this related to running large amounts of methanol in a manifold not designed for wet flow? I am running the power plate btw.
