Valve Spring Help
No way on a flat cam. To tell you the truth i wouldnt use them on a roller either. Way too much for a flat and not enough or barely enough for a roller.
Comp 980 is a good choice. So 980-12
The 980's are a tad stiffer than stock, but perfect stock replacements. Make sure you install them WITHOUT the cups...:cool:
Bison said they were for a roller cam, not a flat stock cam. I think?
The #'s he listed were not for a comp 980. I never even looked at the part #. 125lbs at 1.800 is not a comp 980
