87Turbo-TWE4
- May 9, 2008
I currently use conventional Valvoline with a bottle of ZDDP on every change. My question is, how much ZDDP do you use with VR-1 or any at all?
SignUp Now!^^^^Can someone translate that for me
I have run VR-1 for years with a bottle EOS, and then ZDDP since it first came out.
My engine has been freshened twice in the past couple years with almost 300 passes each time. I have never had a worn rod or main bearing, or any wear issue in the valve train.
I doubt that a street engine during its life would be subjected to the wear and punishment my engine takes between each freshen, so VR-1 and ZDDP would be all you would need.
Just a comment on "tech lines", be it an oil company, or other product, they are always going to tell you their product IS going to work for you, their job depends on consumers purchasing their product.
Just because a product costs more, does NOT make it the best for a given application.
For example, synthetic oils are touted as the "best"? In the real world of boosted engines, their advantage of long life is bogus because our oil gets contaminated with combustion gases and unburned fuel long before the oil reaches its useful life. We change oil at much shorter intervals than the "average" driver, or at least we should.
Synthetic oil has no more "protection" that regular oil, usually less, so it ends up being a waste of $$ unless someones ego feels like he must use the "best".
hello peope; I'm in the thinking a street drivin car goes thru more abuse than a drag engine. A drag race is controlled. You make a pass, tweek some and blast again. ...............IBBY
Do the big name auto stores like autozone and pepboys carry VR-1?
Would it be ok to switch over to the 20W-50?...I have been using 10W-30 for years and just curious to know if it would effect the motor?
