Anyone running these on the street? Savitske Classic & Custom
SignUp Now!The coilover is just not necessary to get ur car to sit right. Would certaily make it easier but the ease comes with a price. Id rather but my money elsewhere.
Not knocken em.... cause id certainly trade mine in for a set if they were free.
LOL Ha, Ha YOU of all people speaking about price and cost? lol EVERYTHING comes with a price! Look at what your dumping into your "Street" car... lolThe coilover is just not necessary to get ur car to sit right. Would certaily make it easier but the ease comes with a price. Id rather but my money elsewhere.
SW.
Lol.... Point taken.LOL Ha, Ha YOU of all people speaking about price and cost? lol EVERYTHING comes with a price! Look at what your dumping into your "Street" car... lol
SW.
Xcessive, where'd you get your red coil packs? You can pm me the info if you like, thanks.I run the QA1 coil over single adjustment with a 450 lb spring. I did not like them on stock A arms because of the way they mounted on the bottom with 2 bolts, they make a plate that mounts to the lower shock with a round plate on it to spread the load now. I have adjusted once on them raising them up very little, had the alinement checked and it was dead on what it was from before.
I liked them because I was tired of guessing what height the car would sit at with standard spring setup. It is not bad to raise just get the right tool and make sure the threads are clean and you have anti seize on them. It will make the job easy. I love the adjustable shocks the tuneability is awsome. Now my car is set up to handle, not a drag setup, so I don't know how well those work.
I do recommend using them with aftermarket A arms, because you can order them just for this application. I have BMR on mine.
How's the weight transfer with the non adjustable QA1 setup??
EXACTLY!! Thats what I was wondering why some would waste time installing / buying several sets of springs to get the desired ride height they want when you can just buy these Once and install Once! Because in the end after the time and money the coil over shocks look like the way to go.which isnt that far off from the price of a new pair of bilsteins and front lowering springs.
