Jerryl knows this method for verifying the actual timing vs commanded, but I thought I would stick it in this thread for others reference.  I copied it from a post I made 5-6 years ago.
With the car running jumper the A and B pins in the ALDL plug, just like you would do if you were manually pulling trouble codes. When you do this with the car running the idle speed is normal and the timing is fixed at 15 deg. This is "diagnostic mode". (This is different than ALDL mode, which fixes the idle at 1000 rpm and adds 8 deg to the normal timing. I seem to remember that TurboLink could put the car in ALDL mode if needed, but I don't seem to remember that capability in Direct Scan or the later scan tools)
Look on the timing tab (guess you should do this before you start the car ), notice that all but one of the marks runs down the left side. There is a single mark on the right side. That mark is, coincidentally, at 15 deg.
So, with the car idling in diagnostic mode, use the timing light to see if the mark on the balancer lines up with that single mark on the right side of the timing tab. The difference will show you how much off the timing ring on the balancer is (if at all). That's assuming, of course, that the balancer 0 deg mark really is at TDC. Which it should be. Check that with a piston stop if need be. I use an old timing light that clips onto the #1 wire instead of a dial back light.
John
 ), notice that all but one of the marks runs down the left side. There is a single mark on the right side. That mark is, coincidentally, at 15 deg.So, with the car idling in diagnostic mode, use the timing light to see if the mark on the balancer lines up with that single mark on the right side of the timing tab. The difference will show you how much off the timing ring on the balancer is (if at all). That's assuming, of course, that the balancer 0 deg mark really is at TDC. Which it should be. Check that with a piston stop if need be. I use an old timing light that clips onto the #1 wire instead of a dial back light.
John
