SignUp Now!any one done one of these things? My brother in law was quoted $3000 from the dealer. Where is the turbo? Any help at all?
If it's anything like the Jetta, it's up front tucked under the cowling/radiator ducting. They use spring clips to hold the charge air pipes on the intercooler (jetta). Once you stretched those out, forget it. Every time on the boost...pop!
You might need an electron microscope to the see the little hill-helper they put on those things.
so how hard is this to change?
Its a mother f---er. Its on the rear of the engine. It comes out the bottom.It pays like almost 5 hours If done a couple at work .No fun at all if the bolts are all rusted on convertor. Is it leaking oil into recirc valve?
Wow thats a big can of weaksauce right there.
Its far from the GTI 2.0 FSI. Especially after a few mods...
The turbo Beetle is a 1.8 liter non-intercooled mill. Mildly peppy, but not on the same page as the GTI. My wife drove a powder blue turbo convert for a couple years. It was good to us.
The turbo resides behind the engine toward the passenger side (IIRC). You can see the aluminum boost tube from the turbo to intake manifold if you look just inboard of the front right wheel. I'm not sure what is involved in replacing it though.
