SignUp Now!Might need to lean it out some. What O2 numbers are you seeing?Might be some of it but it was violent from 55 really put you in the seat just makes noise now and pulls so so....
How long do you have to stay in it to get the O2 number down to 760?O2 numbers are about 760 so I don't think it rich about the same as it was with cooler air.
Fwiw it was able to smoke the tires from a 25-30 roll now it just maybe turns them a little when the boost first hits. It's not as awful as I first indicated probably. It was really slamming me and my in unsuspecting wife back in the seat when I punched it to pass or something now its just a mild shove.
love this turbo Buick app btw just uploaded a picture of my car as a test.
When you first get on it,the O2 numbers should be in the 830s then fall to 780ish at the top of third gear. If it starts out at 760,it's too lean. I would richen it until the first numbers you see are in the 830s.I only get on it for a couple three seconds.
I hooked up a pressure gauge z couple weeks ago and the pressure is rising correctly it seems.
O2 has always been lower than average but since the alky went on knock has never been an issue.
Again,you want to see 785 at the end of a full quarter mile pass. If you're seeing it shortly after you go WOT,you're lean. You should be above 800.Ok I love my car again they grew back
Drove it to work this afternoon sunny mid 70s...
Car felt good love my new stereo too!!
Dropped the hammer at 30 mph and it was smoking the tires and sideways to 60 mph or so !
I think it was the three passengers I had with me that made it feel slow with an extra 300 pounds I guess.??? Boost was 21 peaking at 22 now that it's warmer lowest o2 was 785 knock was .5 fwiw.
I did smell some burning oil once today when I ran into the store and got back in with the door open when I started it. I'd not been running if hard before that time . Then when I park it in the shop ii didn't smell any ... The car is possessed.
Are you using your alcohol?I'll bump the fuel 10 % and see what that does next time.
What fuel filter do you have? What octane?when I first punch it the O2 goes low and seems to climb every update on the scan master. It may show a low of .720 but if I watch it like from a 40 to 80 run at 80 its reading .780 or so.
