I can relay the exact same sentiment.I don’t know much about the TA water pump other than Duttweiler was involved with the testing of it some years back and it did show improved cooling compared to a stock pump. I don’t have any real data so take that for what it’s worth.
The consensus I found when looking into water pumps is that the parts store one’s will probably work just fine for most. Personally, I used a FlowKooler 1621 1973-1987 Buick Cadillac Chevy GM Olds Pontiac Grand National 196
This. It costs more than the parts store one but it is a quality piece.FlowKooler for the Win
Buy once & be done !
Flowkooler high flow pump 1621 has a 16 vane CNC machined billet impeller. It is shrouded and ported and, with the increased vane count and a reduced impeller clearance, it really pumps the coolant. It achieves greater flow rates, higher head pressure and a more efficient flow. The impeller's...flowkoolerwaterpumps.com
I'm done buying cheap auto parts. My time is more valuable than having to replace the same part multiple times, so I just buy the best and move on with my life.I just used the cheapest one from the local parts store.
I just bought the car last week and it's been leaking slightly from the water pump weep hole. Maybe a cup every couple of days. The car had been sitting for almost a year without being driven so, I'm giving it a chance to stop of its own accord. Seems to be leaking less today. Before buying a new pump I'll add some of the Delco stop leak pellets which have worked before for very small leaks. I just want to be ready to buy a new pump if the leak persists.Just curious, what’s wrong with the current water pump ?
Ah, thanks for your reply. I got very similar issue going on too. I suspect it’s my water pump as well. I can smell coolant only when I drive it for a bit. Seen some coolant drops near the oil drain plug after a cruise. Need to pressurize the coolant system and verify. Getting to damm old to be crawling under this car anymore lol.I just bought the car last week and it's been leaking slightly from the water pump weep hole. Maybe a cup every couple of days. The car had been sitting for almost a year without being driven so, I'm giving it a chance to stop of its own accord. Seems to be leaking less today. Before buying a new pump I'll add some of the Delco stop leak pellets which have worked before for very small leaks. I just want to be ready to buy a new pump if the leak persists.
You and me both, brother.Ah, thanks for your reply. I got very similar issue going on too. I suspect it’s my water pump as well. I can smell coolant only when I drive it for a bit. Seen some coolant drops near the oil drain plug after a cruise. Need to pressurize the coolant system and verify. Getting to damm old to be crawling under this car anymore lol.
Swap it ASAP. It's only gonna get worse...and it's not a bad job to do from a time stand point.I just bought the car last week and it's been leaking slightly from the water pump weep hole. Maybe a cup every couple of days. The car had been sitting for almost a year without being driven so, I'm giving it a chance to stop of its own accord. Seems to be leaking less today. Before buying a new pump I'll add some of the Delco stop leak pellets which have worked before for very small leaks. I just want to be ready to buy a new pump if the leak persists.
I think much of the issue guys have is the cars sit for long periods of time and seals/gaskets dry out. I have a friend that's a parts manager and he let's me know who the part is made byI'm done buying cheap auto parts. My time is more valuable than having to replace the same part multiple times, so I just buy the best and move on with my life.
