SignUp Now!Thats what I ended up doing, But they had issues as well and so did their down pipe.... but we fixed every thing and all is good I assume they have all of the bugs worked out by now.Or, step up to the plate and buy a set of Stainless Steel TA race headers and be done!
Do you have any pictures of these welded on factory manifolds?You can cut and weld in bellows in the cross over to help reduce the side load on the headers. This seems to help a lot. The material is 409 stainless and does not require back purging. I use to gas weld them and I think that worked better than MIG or TIG. I usually TIG them because I rarely gas weld anything anymore, so my set up isn't "handy". If you do buy bellows make SURE it is like this style and NOT one with outer braid. http://www.reidwashbon.com/racing_parts_racing_products/bellows.aspx
No, sorry. They don't go on the manifolds, just the cross over. They are not cheap Chinese pieces, either. The stock cross over pipe is very thin and at high boost cracks due to extreme heat and pressure.Do you have any pictures of these welded on factory manifolds?
