SignUp Now!I know the newer motors can make a ton of power, but the cost can still get up there.
I'm definitely not arguing with you. You just answered my question. Going 140 MPH even with an ls is still going to cost quite a bit. Less than an lc2, but still a lot.Price what it takes to get a LC2 to run 140 in a TTA ... then tell me how viable it is compared to $2700
I would be willing to bet you have that much in a mid 11 second TTA
I'd have never expected to raise such a debate, but I think at this juncture I'm willing to finally concede that a TTA is a "nostalgia" car. Fun for sure, but I'm done trying to aim to run with the fast late models. It's just a little sad to see guys I used to work-over running fast enough that I'm not going to even try going after them.
I've done similar with an end mill to achieve a very good surface to press against with the fastener using to preload. I preloaded .001" then resurfaced after preloading. I did the intake side because of the lack of support in that area. Never had a problem on the ex side. The spark plug boss adds material where it's needed.For guys pushing the iron TTA heads just do what I have been doing for years on them. Pin the decks like Pro Stock guys did in the 70's. Drill holes down from the inside of the valve cover side of the head. Drill centered over where the fire ring is on the intake side. Tap the upper surface and just let the drill touch the inside of the lower surface to create a drill start. Use a quality bolt and machine the end of the bolt to match the drill tip angle. Tighten the bolt with JB weld on the threads and using a dial indicator preload the deck .0005" then take a cut off wheel and cut the bolt down almost flush with the upper surface.
On the out board side of the head repeat these steps in two places on each side of the spark plug boss, again centered over the fire ring of the head gasket.
This should be done on a mill to be precise, but a drill press will work fine, too. I use to do this to the GN castings (except on the exhaust side) but now with big injectors we don't seem to have issues blowing head gaskets like we did in 1988. If you need any additional info PM me for my phone number and I can walk anyone through this simple mod.
Start a thread and I'll make it a stickyThe GN heads (8445) are well supported but the TTA heads are not. I have heads all cut apart to verify weaknesses. The GN heads exhaust side is ALOT stronger. To get the pin located on the 8445 castings in the right spot you need to mill the rocker pedistal a lot. I have pics somewhere of the 8445 heads I can post if anyone is interested in the process. I only have one set of TTA heads on the shelf but could do the mod and post pics if someone wanted to buy a set of ported TTA heads for my "troubles". It would take me a few months to do the work. I will be laid up for awhile for surgery soon.
When I first started reading this I thought you were kidding until I got further down. I was envisioning taking the valve covers off, and driving some tech screws through the head in to the block. Eeek!For guys pushing the iron TTA heads just do what I have been doing for years on them. Pin the decks like Pro Stock guys did in the 70's. Drill holes down from the inside of the valve cover side of the head. Drill centered over where the fire ring is on the intake side. Tap the upper surface and just let the drill touch the inside of the lower surface to create a drill start. Use a quality bolt and machine the end of the bolt to match the drill tip angle. Tighten the bolt with JB weld on the threads and using a dial indicator preload the deck .0005" then take a cut off wheel and cut the bolt down almost flush with the upper surface.
I went 133 mph. Could never get the 60 to match the mph so that was it for me using the TTA heads.did you go 9.99 with stock tta heads on a sg1 block ?????
I think Julio is the MPH king with the TTA heads.whats the fastest mph 1/4 with TTA heads ??
She is back to stock now. Still a fun car to drive. I have a T-type now with the stage II block and TA aluminum heads with 14 bolts. Lets just say its a lot easier keeping the heads in place.yes I was there ! your car looked very clean
