boostingbuick
Going to be buried in this.
- Aug 25, 2002
So what is everyone using for a aftermarket crank? I may need to buy a crank and was seeing what people are using.
SignUp Now!................As far as what crank to run, It seems you should run whatever you can get your hands on, Forged crank supply is awfully short at the moment.
What would a complete stroker set up cost for a Daily street driven 109 block?
I run a 4.1 block, so a stroker kit is out. And the piston I am sure are fine. I just want to know that I can get a crank. I am not sure that I will even need one. And I have heard bad things about the Eagle cranks. Just want to know my options if I need one. Thanks.
I run a 4.1 block, so a stroker kit is out...
