What could cause low TV pressure?
BM Computer Src
After I had my transmission rebuilt, I have had a big problem with it shifting correctly duer to low TV pressure. The shims I have put in to the TV cable (by the base of the transmission) have helped, but not cured it. Anyway, I was wondering why it would need shims to help bring up TV pressure? Is there a list a mile long that I would have to go through? I can take pressure readings in about 2 weeks, when I will have a gauge. Until then, I would like to know what the possible causes of low TV pressure could be, which parts I would most likley need to look at. I did have a 10 vein pump installed.
It may have something to do with who built it :rolleyes:
Maybe he didnt install the updated pressure regulator for the pump..look into the stregnthening the 2004r and read up on the pump..especially the Hack way of doing things :D
Good point... I learned a hard lesson with this rebuild. I'll never go to a non-buick trans guy again... Grady's Greasy rebuilds just didn't get it right. Thanks for the info.
