ok guys, need some expert advice here.
i just finished up putting in a pts shift kit, followed the instructions to a T, i'm positive i did all the valve body mods correctly and nearly 100% positive i put it all back together correctly. also installed a new tcc solenoid.
so i added 3 qts of fluid, fired it up, got to operating temp and then checked the fluid level. said i needed about a quart more, so i added 1.5 quarts, (bc we're supposed to overfill them) get in the car and even in park the engine revs like its under load. then i discover that the car moves forward in EVERY gear position. (except park, but it still is trying to move.) put the car in D, and try to move forward a little, the car will move but it revs really high and will stilll just creep along. i didn't actually drive the car, but this is pushing it out of the garage and driving back in, so maybe 30 ft. what happened?
fluid level still says its over full. i really don't think its mechanical, rather fluid related but i know little to nothing about transmissions. any suggestions/advice would be much appreciated. thanks in advance gentlemen.
Talon
![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
Talon
