What is done to modify a ECM ?
Beamer
I have 55 lb injectors in my T. I have assumed (don't say it...), that I have a modified ECM, as anything above 50 Lbs injectors needs to be modified for the low impediance. I have also heard that some 55 Lb'ers do not require modifying the ECM.
I will be installing a powerlogger next week, and I was curious how to tell if it has been modified for sure.
Thanks all...
Mike
All of the guys that modify ECM's with the proper peak and hold drivers also attached labels to the aluminum case indicating the modification.
sorry, i can not help with the injector question.
John
Mike,
First, visit this website: racetronix - index
(("Z" = Impedance)
There you will find the listing
for the various hi-Z & low-Z injectors.
Factory GM ECMs in TRs were built for the hi-Z injectors.
Modded TR ECMs can utilize the low-Z injectors.
There are both hi-Z and lo-Z 55#s.
The overwhelming odds are that yours are the hi-Z 55#s.
Likewise, the same odds stand on you having an unmodded ECM.
Since Bob Bailey does all (or practically all) the TR
ECM injector driver mods, he'd be a good one to ask
any further info as to identifying the modded units.
Look for the "Ask Bob" forum on the fullthrottle website.
HTH
Thanks all...
Mike
Mike, I've got 60lb Mototrons on my GN and no ECM work. Fyi...
Thanks for the info Ryan...
I guess what I am really wondering about, is if in the future... I want to upgrade my injectors to a larger size - will I havee to get my ECM modified, or buy one that has been modified.
Enjoy all...
Mike
I took a modified ECM apart just to see what is involved. To make is short I would rather leave it to the experts to make the mods. Just my .02..
Enjoy all...
Mike
Check the numbers on your injectors, and post them...
Back in the day, the largest hi-z injector was the 42lb 009, and the 55 lo-z was the hot ticket in upgrades. The Mototron 60s are probably the finest injector ever used on these cars, and they're just about all the injector needed- especially with alky.
If history is any indication, there will continue to be improvements to hi-z injectors, and modded ECMs won't be as necessary.
If Bob modded your ECM, there should be a date sticker on the case.
HTH!
Enjoy all...
Mike
There are 79# hi-Z injectors available now @ racetronix - index
for use with the stock un-modded ECM.
When/If you wanted to ever run low-Z injectors, it'd be
ideal to get a new (refurbished) ECM from GM & send it
directly to Bob Bailey @ fullthrottle for his low-Z mod.
ECM part # is @: Turbo Regal Web Site
Check price of ECM @ GM Parts Direct: Your direct source for Genuine GM Parts
HTH
You can reference & compare the numbers found on your current
injectors easily by using the injector list provided on racetronix - index
All the data on each injector size/type
is quickly found by merely clicking on its listing.
HTH
is there advantages or disadvantages to running low z or high z injectors....
would 72#low z perform better than 79#high z ????
HTH!
I looked at them last night, and they have 3102 on them. I saw some 55# injectors on the boaed a month + ago, that were identical to mine, and had the 3102 on them.
Any luck in helping me determine low or high impedance is appreciated. The main question is if my ECM is modded or not. If I decide to jump up to larger injectors, it would be nice to know...
Mike
low Z injectors in this size range (when properly controlled by a peak and hold driver circuit) tend to have more stable, predictable fuel delivery at low pulsewidths. Meaning that your idle and cruise AFR should be steadier, and more consistent.
Bob
P&H Drivers
There are P&H injector driver chips (LM19194?)I don't have the number at my fingertipa and my memory aint so good.....well you should be able to build an interface box to drive any injector. If anybody is interested, I'll look up the number/circuit.
J N
I see that there is a different type IC module to drive the injector circuit, is this a replacement IC chip? Sometning that has to be installed by modifying the circuit board? And I understand that there are some resistors that need to be added also.
I saw that FTS was selling modified ECMs for low impedance injectors, but it looks like they do not do that any more. Who modifies them now?
Mike
Mike
3102:
Racetronix-Siemens_Injector_Sale-55h
If you do not want to mod your ECM you can use an impedance converter box. We have V6 versions w/injector packages as well:
RX-ICH
3102:
RX-ICH
I see the old part numbers on the low impedance injectors, and that is what I have. I assume that my ECM is modified then.
Would they even work if my ECM was not modified? In other words, what would a car do if someone put low impedance injectors with a stock ECM?
I am trying to learn my boundries for the future.
Thanks,
Mike
