Jay Nesbitt
Lurker Member
- Apr 22, 2003
Low impedance injectors WILL work under some circumstances for a time. The drivers will eventually burn up. The last time I looked for an injector driver (or impedance matching) box, I found the AEM @ $400. That's when I started looking and found the National Semi. So if you have the bent, I believe you can make a box for, say $10 per inlector, or if not buy a premade one...or modify the ECM for P&H drivers. Although there are some variatins in ratings, typically a 55PPH injector is low impedance.
jn
jn
