- May 25, 2001
One thing to look at with spooling a larger turbo is you can change exhaust housings to tailor the turbo to your car. I'm working on a deal that will either net me a BB-70 (Q-Trim) or a Non-BB 70 (P-Trim). With the Art Carr 19930 thats in my car spooling a P-trim 70 with a decently large size exhaust housing (.85 PTE) should be no problem. If I go with the BB-70 I will also look at a .85 housing due to the fact the BB turbos do spool faster. I want a little lag so the car is tamer leaving from a stop.
You can get .63 Garret .63 PTE .8? Garret .85 PTE among other exhaust housings.
Turbonetics and Garret make BB setups. The Turbonetics one uses a BB on one side and the Garret uses BB on both sides. Both are expensive
If I remember right, If you look a PTE 5x turbo compared to say a Limit Eng. 49/44/60/61 you will see one less blade on the exhaust wheel. That may be what helps the spool-up (less blades, less weight, easier spool)
When I was comparing my TA-54 with my friends 60-1 Stage V Big Shaft P-trim the exhaust wheel on his looked to have a different pitch to it. that will affect the way the turbo spools too.
