what are the "rules" for keeping a Hotair "correct"?
adding an intercooler is a no-no, but adding an alky kit that gives you a chemical intrcooling effect is ok.
what about a water-to-air intercooler setup?
or, how about an incercooler that runs off the AC pump like in the Ford Lightning pickup?
i'm just asking, becasue someday, when i actually have some money to play with my T Type, i'm gonna want to make it fast and reliable. i'm not a fan of things like nitrous or alky injection- they need to be refilled and if you run out, you are without that boost. i prefer the kinds of things that you don't need to worry about, and an intercooler falls into that catagory.
I don't claim to speak for any of the hot air crowd, but heres my "rule" that I base my statement on when I say I stick to the "hot-air" setup. I speculate that a Ic'd guy explaining to someone else that the differance between the 2 is that the hot airs didn't have the air-air intercooler, and location of the turbo was differant. And I think thats a pretty satisfactory general statement to say . Unless you wanted to get into all the differances like intake, mech fan, belt setup, etc. those 2 things are the most noticeable when you open the hood, and to move the location of the turbo up front or install the intercooler, is going to alter appearance of the factory setup in a fairly big way. (performance whether better or worse, is not the issue imo) And,... also should mention, its going to make the fairly low number 84/5 production car now resemble the much higher production 86/7 car. (low- meaning sum of 86/7's tb's are much higher than 84/5's) Does the average ic'd turbobuick enthusiast give a flip that the hot-airs are alot more rare? nope, (probably would if the hot-airs where bringing in the bigger bucks though
I don't even give a flip, and I own one. I, just like a lot of the other hot air owners who drop in here once in awhile, like to keep their baby in its rare original form, and, enjoy the challenge of getting the performance out of it that can rival the performance of the air-air ic'd cars.
I don't think that adding bigger turbo or alky kit, cai, etc... is affecting the general apperance of the hot air setup.
Having said all this, I hope somebody pours a can of ball bearings into Project TNX's intake when its all done.
HAAAA! Just joking. I wasn't trying to knock your engine about the paint Tnx (in case you took it that way). Check this out. I have a powder coater at work that I play with once in awhile. I did the heat shield and uppipe glossy white on my daily driver 86 T. I get some pretty strange looks from some of the local tb guys when I open my hood. I don't know if I'll do them white again, but its holding up so well that I may just leave it for awhile, powder coat is a pita to remove. :frown:
