what is the torqing sequence for crank caps ?
bpman1234
hi just want to check my crank with plastigage is there a sequence to torqing down the crank caps any help would be great thanks .
Not really, pull both fasteners in several steps making sure you get both bolts/studs fully to the correct torque on the main you are checking and do NOT turn the crank with the plastigage in there.
