Going to go look at this 87 GN and probably buy it. Here is a list of parts it has. Is there anything you would add or take away? Thanks for the suggestion and comments!
HP Engine rebuild kit (fillet-rolled crank, pistons, camshaft - 254 duration & 430 lift, hi-rev lifters & springs, performance cam button & spring, perfprmance double roller timing chain, lube pump)
New Air Conditioner (compressor, condensor, orifice)
Brake Accumulator
Idle Air Control motor
Suspension idler arm (front)
30 psi column mounted boost gauge
T - Top parts & gaskets
TE-44 Turbo (adjustable boost)
New turbo oil supply line and gasket
3 " Downpipe
New open exhaust w/ mufflers
Center Arm Rest
Custom powder coated valve covers
TPS - TEC Enhancer
Scan Master 2 Diagnostic Tool
"Thrasher" Computer Chip
Fan Delay Relay Switch
Engine torque strap
Rear Seat Cross Braces
Rear wheel bearings & axle seals
Pioneer Receiver/CD Player
Infinity Kappa 6 1/2" door speakers
Infinity Kappa 6 X 9 Rear Speakers
GM By-Pass "S" Hose
Stainless Thermostat Housing
160 Degree Thermostat
Heated O2 Sensor Kit
Hi-Performance Coil Pack
New dimmer switch
4 Hi-Output Head Lamps
Head Lamp Booster Wiring Harness
RJC Power Distribution Plate
Ceramic Headers & copper gaskets
Fiberglass Bumper Fillers
High Performance In-tank Fuel Pump
Adjustable Fuel Regulator
New Fuel Tank
New Crank Position Sensor
Air Conditioner Supply Lines
Power Master brake motor
New exterior paint (stripped to metal then primer - promoter - paint - clear)
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Brake Accumulator
3 " Downpipe
Center Arm Rest
TPS - TEC Enhancer
Engine torque strap
GM By-Pass "S" Hose
New dimmer switch
New Fuel Tank
