crazyttypechic6
- Mar 11, 2014
Here is some history, went to make a pass on drag strip, heard a tick and then some knocking in the burn out took car back to trailer and hauled it home. Got home pulled valve covers found a broke rocker shaft, cracked rocker arm and one bent rod.
replaced rocker arm shaft assembly and all push rods on both sides. Also removed intake prior to replacing rods and rocker arm assembly and found one piston laying out of its slot. Put it back down in its slot and then replaced rods and rocker arm assembly. Sorry got the story out of order a bit. We also replaced the valley pan and gasket set under intake. Once all was replaced and put back together and noticed and intermittent ticking noise on the driver side, now to note the rocker arm and shaft cracked on the passenger side, now the noise in on the drivers side.
Today I drained a quart of oil and added one MMO and its still ticking intermittently.
Listen to this video...
http://www.youtube.com/edit?o=U&feature=vm&video_id=_thb_pezh7w
