What Kind Of Atf To Use In 200r4????
PHANTASM
POWERED BY POVERTY
anyone use something different than dexron atf?
trans was built by len freeman and has a brake.
what is the best fluid to use?
does the cast aluminum pan kit offer any performace gain/longevity for the trans?
thanks for any info/help.
Dexron III is all you need. Extend the pickup tube and use a bottom rear feed filter in the deeper pan. Extending the pickup and bottom feeding will mini,ize the chance of cavitating and burning the forward clutches or direct drum on the 1-2. Definitely needed for a hard launching car with a brake.
the fluid still looks good. was just going to upgrade the system and put new fluid/filter in.
the trans performs flawlessly and shift very,very nice and firm everytime.
so dexron 3 it is along with the cast pan and extended filter.
thanks,steve
