Aug 29, 2012 #1 K KevinB Well-Known Member Joined Dec 2, 2004 Messages 6,438 I need to add some inputs and outputs. If I go to Napa, what kind of pins does this ecu use?
Aug 30, 2012 #2 H HighPSI Moderator Staff member Joined May 24, 2001 Messages 5,978 They are from a Honda ecu. I would be REAL surprised if you find them at Napa. Caspers has them. We also have them with or without the wire attached.
Aug 30, 2012 #3 K KevinB Well-Known Member Joined Dec 2, 2004 Messages 6,438 What's the trick to pulling a pin out then? I use a lead not being used then since I need it asap
