Don't scrimp on the mic set. Get a good name brand set. Used is fine as long as it's old enough to be quality yet new enough to be modern. A set of standards good to have too. If they aren't calibrated you can't check anything but clearances.
On the bore gauge I've had good luck with the Shars set. I've put my gauge against a Snap-On and a Mitutoyo bore gauge and the all three read the same and the repeatably was the same. If you look in the 'how-to' section where I spent way too much time going over my rods you can see the exact tools I use.
