What Mixture Do ya run??
JUSTAV6
Getting High On PSI
Ok, I will be getting my smc kit next week, So what do you mix, Ive found some 99% isopropyl will this be ok?? and do I mix anything else?? and could anyone give me some tips,
Thank You all for the help!!!
Seneca Lafler,
No mixture.....Denatured Alcohol.
Steve recommend adding a few shots of DW-40 to keep the pump from corroding, however I don't think it's needed with denatured.
HTH
100% pure denatured alky
i spray zep 45 in the bottle just enough to lube the pump.
dont allow the bottle to empty completely, or it will dry out the pump.
If you get the Iso. cheap or free it will work fine.
If you have to buy the stuff at normal prices Denatured works a bit better.
If I got free Iso. I definately would use it. :)
So if I run Iso It wont hurt anything?? And do I still have to use like WD-40 with it?? I can get The Iso for like $119 for a 16oz bottle from meijer, So I Will be OK with this,????
Thanks Alot For The Replys
Seneca Lafler,
That is $9.52 a gallon. You should be able to find denatured for 8-9$ a gallon. If you dilute it to the same percentage as the iso, it will be much cheaper. If you leave it straight, it is a little cheaper...why waste money on the iso when it does not have as good a properties for our particular usage? :)
Ok! Now I Know what to use How much WD-40 do I use??
Thanks For all The Replys,
Seneca Lafler,
A two second count squirt.
One...two. That's it.
Should appear slightly brown on top, kinda yucky looking. :)
