What size injectors?
87LimitedT
Just getting started
I’m wanting to upgrade my injectors but I have a stock turbo and I don’t want to go to big but I don’t want to have to buy another set when I upgrade to a larger turbo I was thinking 42.5 lbs would be good but then I also think they may be to much for me.
60lbs are the way to go will work with youre stock set up and have plenty of room to grow in the future also get a TURBO TWEAK chip for them you will love it.:biggrin:
Size really wont affect the way the car drives, its more in the chip burner, and turbotweak has got it down for 60lbs. injectors.
there is no reason to go small here, 60's will allow for more room if and when the bug bites you! i got the 60's and chip combo from turbotweak and they are great. hth.
60lb. injectors and TT chip. Those will be the last injectors and chip you'll ever need to buy. Great driveability on the street too. ;)
x3 TTchip and 60's. I put this combo in my car and it worked great right out the box.
60's
X5 yup listen to these guys wish I would've gone 60's instead 009's should have spent little extra instead of saving a few bucks. Eric cuts you a deal for buying both injectors and chip from him plus I believe 60# injectors are flow matched where as the 009's are not. I could kick myself in the arse so now if I ever want to go bigger Turbowise I'm going to have spend 300+ dollars.
60 are flow matched and my car idles much smoother with the 60's than with the 009's I had.
Those of you with 60 lb injectors and the Turbo Tweak what fuel PSI are you running?
Nobody has taken the time or effort to tell you this so I will let you in on the secret: 60#'s and a TT chip.
I am your only friend since no one else mentioned this to you.
